Getting error while creating a door in Level 2
abdul.rafee
Message 1 of 26
abdul.rafee
I am trying to place a door on Level 2 but failed to say that cannot cut the instance of the door out of the wall.
below screenshot for you better understand
below my code
Replies (25)
Message 2 of 26
jeremy_tammik
Maybe the wall is simply too short to host that specific door? Can you place the door in the wall manually using the end user interface?
Message 3 of 26
sayu94
Hello. I see xyz - may be it point not in line of wall? you must create new door in point in the wall.
Message 4 of 26
abdul.rafee
I tried to manually copy the door level 2 it's working fine.
Message 5 of 26
abdul.rafee
Yes, you're guessing was correct  I am creating a door with the same XYZ point and changing level 2 but not working.
Message 6 of 26
sayu94
use point on level 2
Message 7 of 26
abdul.rafee
Yes, you're guessing was correct I am creating a door with the same XYZ point (z value 0) and changing level 2 but not working.
Message 8 of 26
abdul.rafee
how I can use it on level 2 in coding this is confusing
Message 9 of 26
sayu94
if you want to insert door in wall on level2 - you must use this wall and point in this wall
Message 10 of 26
abdul.rafee
I am creating a wall on level 2 only using the same wall to create the door
Message 11 of 26
sayu94
FamilyInstance must have Host and you can use exactly wall on level2 and point exactly on level2, not z=0
Message 12 of 26
abdul.rafee
even though I changed the z value to a desired elevation, but same problem
Message 13 of 26
sayu94
Our new Zcoordinate on line wall on level2? And you use by host exactly wall on level2?
Message 14 of 26
abdul.rafee
This means you say that use the same z value while creating a wall on level 2 is that correct?
Message 15 of 26
sayu94
Message 16 of 26
abdul.rafee
Very good explanation, is exactly what I am looking how I can get that point I tried with level id and also tried with z elevation.
Message 17 of 26
sayu94
You can use project your first point ol line location wall
https://www.revitapidocs.com/2019/b87fc3e4-ea25-2a75-5b5a-53065b099d2a.htm
Message 18 of 26
abdul.rafee
Many thanks to support, I will try and then let you know
Message 19 of 26
abdul.rafee
I tried but did not succeed. let me know if you have any solution much appreciated.
Thanks.
Message 20 of 26
abdul.rafee
I tried but did not succeed. Let me know if you have any solution much appreciated.
Thanks.
