Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Getting elements passing through opening
1 REPLY 1
ameer.mansourWAK8Y
332 Views, 1 Reply
is it possible to get elements passing through openings?
if yes, how to get point of intersection with the opening as if there is an object that represents the opening.
do I have to create an object to substitute the opening and get my result? is there other cleaner way?
1 REPLY 1
The first approach that comes to mind is to create a temporary in-memory solid representing the opening geometry.
You can use that solid to define an intersection filter and retrieve all elements that clash with that.
The Building Coder discussion on using an intersection filter for linked elements shows you all the required steps and more besides:
https://thebuildingcoder.typepad.com/blog/2018/12/using-an-intersection-filter-for-linked-elements.h...
One way to detect the exact intersection surfaces where the clashing element enters and exits the opening geometry would be to project its geometry onto the front and back opening surfaces an use a 2D Boolean operation on that:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.2
You can probably also achieve the same using the ExtrusionAnalyzer class:
https://www.revitapidocs.com/2019/ba9e3283-6868-8834-e8bf-2ea9e7358930.htm
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
