Getting Elements from BoundingBoxXYZ
Hi!
I have some BoundingBox ang a want to get all Element inside this Box.
Any suggestions?
matthew_taylor
Hi @Anonymous,
There are element filters for that:
Dim bb As DB.BoundingBoxXYZ = elem.BoundingBox(view)
If bb IsNot Nothing Then
            Dim min As DB.XYZ = bb.Min
            Dim max As DB.XYZ = bb.Max
            Dim outline As New DB.Outline(min,max)
            Dim bbfilter As New DB.BoundingBoxIsInsideFilter(outline)
            ' Don't use a view to construct the filter
' as it won't return good results for some view types. ' will need to refine this function if we want only elements
' visible in the view. Dim collector As New DB.FilteredElementCollector(m_doc) collector.WherePasses(bbfilter) ...
I'm pretty sure those comments come from either @jeremytammik or someone on this site somewhere...
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
