Getting coordinates for faces of MEP spaces
ottosson_mathias
ottosson_mathias
I want to visualize different faces of MEP spaces in 3d using Direct3DContext (in a later step).
I've collected all MEP spaces from my model, and then use Element.get_Geometry to get the geometric representation:
var geometry = space.get_Geometry(new Options
    IncludeNonVisibleObjects = true,
But after this I'm not sure what to do to get the coordinates to be able to draw individual faces of the space
In the PlanarFace objects I can not find enough information to draw it... Maybe I misunderstand something, but from what I can see I need a Length property to be able to draw using this information. Origin, Directions (XVector, YVector) is not enough, right?
jeremytammik
You can use the geometry information that you point out. It contains all the information you need.
There is an easier way, though: you can query the Space element for its ClosedShell property:
https://www.revitapidocs.com/2020/e7dbd26c-ef27-f95c-8b14-87764e86b35a.htm
That provides nicer results than the Face objects in the geometry; the former is a closed shell, the individual faces may have gaps between them.
Here are samples visualising rooms using AVF, DirectShape elements and glTF to display the ClosedShell data:
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
ottosson_mathias
Thanks a lot!
