getting ceiling grid lines from linked file
ameer.mansourWAK8Y
ameer.mansourWAK8Y
Hi
I want to get these lines of a ceiling grid from linked file
I tried this way but it seems not to be working when the ceiling is in a linked file
https://forums.autodesk.com/t5/revit-api-forum/dimension-on-hatch-pattern-slab/m-p/7063302/highlight...
   private void test(Document ActiveDoc, Ceiling elem)
            Reference r = HostObjectUtils.GetBottomFaces(elem).FirstOrDefault();
            PlanarFace face = elem.GetGeometryObjectFromReference(r) as PlanarFace;
            XYZ corner = null;
            foreach (Curve cv in face.GetEdgesAsCurveLoops().FirstOrDefault())
                corner = cv.GetEndPoint(0);
                break;
            var HatchLines = AnalyzeHatch(ActiveDoc, elem, r);
            if (HatchLines.Count > 0)
                using (TransactionGroup tg = new TransactionGroup(ActiveDoc, "align2RefPlane"))
                    tg.Start();
                    foreach (var HLine in HatchLines)
                        ReferencePlane pl = null;
                        using (Transaction t = new Transaction(ActiveDoc, "CreateRefPlane"))
                            t.Start();
                            pl = ActiveDoc.Create.NewReferencePlane(HLine.Item3.Add(HLine.Item4.Multiply(3)), HLine.Item3, face.FaceNormal.Multiply(3), doc.ActiveView);
                            pl.Name = string.Format("{0}_{1}", "ref", Guid.NewGuid());
                            t.Commit();
                        string stableRef = string.Format("{0}:0:{1}", pl.UniqueId, "SURFACE");
                        Reference ref2Plane = Reference.ParseFromStableRepresentation(doc, stableRef);
                        using (Transaction t = new Transaction(ActiveDoc, "align2RefPlane"))
                            t.Start();
                            ActiveDoc.Create.NewAlignment(ActiveDoc.ActiveView, ref2Plane, HLine.Item2);
                            t.Commit();
                        using (Transaction t = new Transaction(ActiveDoc, "MovePlane"))
                            t.Start();
                            XYZ translation = HLine.Item3.Subtract(corner);
                            ElementTransformUtils.MoveElement(ActiveDoc, pl.Id, translation);
                            t.Commit();
                    tg.Assimilate();
        /// <summary>
        /// Analyse the hatch
        /// </summary>
        /// <param name="elem">An element with surface hatch.</param>
        /// <param name="hatchface">The reference to the face to analyse.</param>
        /// <returns>Returns:
        ///  foreach hatchline in hatchpattern
        ///  item1 = index of hatchline in hatchpattern
        ///  item2 = reference to the hatchline
        ///  item3 = point on hatchline
        ///  item4 = direction of hatchline.</returns>
        List<Tuple<int, Reference, XYZ, XYZ>> AnalyzeHatch(Document ActiveDoc, Element elem, Reference hatchface)
            var elemDocument = elem.Document;
            //check for model surfacepattern
            List<Tuple<int, Reference, XYZ, XYZ>> res = new List<Tuple<int, Reference, XYZ, XYZ>>();
            PlanarFace face = elem.GetGeometryObjectFromReference(hatchface) as PlanarFace;
            Material mat = elemDocument.GetElement(face.MaterialElementId) as Material;
            FillPatternElement patterntype = elemDocument.GetElement(mat.SurfaceForegroundPatternId) as FillPatternElement;
            if (patterntype == null) return res;
            FillPattern pattern = patterntype.GetFillPattern();
            if (pattern.IsSolidFill || pattern.Target == FillPatternTarget.Drafting) return res;
            // get number of gridLines in pattern
            int _gridCount = pattern.GridCount;
            // construct StableRepresentations and find the Reference to HatchLines
            string StableRef = hatchface.ConvertToStableRepresentation(elemDocument);
            using (Transaction t = new Transaction(ActiveDoc, "analyse hatch"))
                if (!ActiveDoc.IsModifiable)
                    t.Start();
                for (int hatchindex = 0; hatchindex < _gridCount; hatchindex++)
                    ReferenceArray _resArr = new ReferenceArray();
                    for (int ip = 0; ip < 2; ip++)
                        int index = (hatchindex + 1) + (ip * _gridCount * 2);
                        string StableHatchString = StableRef + string.Format("/{0}", index);
                        Reference HatchRef = null;
                        try
                            HatchRef = Reference.ParseFromStableRepresentation(elemDocument, StableHatchString);
                        catch
                        if (HatchRef == null) continue;
                        _resArr.Append(HatchRef);
                    // 2 or more References => create dimension
                    if (_resArr.Size > 1)
                        using (SubTransaction st = new SubTransaction(ActiveDoc))
                            st.Start();
                            Dimension _dimension = ActiveDoc.Create.NewDimension(ActiveDoc.ActiveView, Line.CreateBound(XYZ.Zero, new XYZ(10, 0, 0)), _resArr);
                            // move dimension a tiny amount to orient the dimension perpendicular to the hatchlines
                            // I can't say why it works, but it does.
                            ElementTransformUtils.MoveElement(ActiveDoc, _dimension.Id, new XYZ(.1, 0, 0));
                            Reference r1 = _dimension.References.get_Item(0);
                            XYZ direction = (_dimension.Curve as Line).Direction;
                            XYZ hatchDirection = direction.CrossProduct(face.FaceNormal).Normalize();
                            XYZ origin = _dimension.Origin.Subtract(direction.Multiply((double)_dimension.Value / 2));
                            res.Add(new Tuple<int, Reference, XYZ, XYZ>(hatchindex, r1, origin, hatchDirection));
                            st.RollBack();
            return res;
Replies (0)
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
