GetParameterValue2
GetParameterValue2
Message 1 of 8
GetParameterValue2
how to get  "GetParameterValue2"  varaible from Revit API, where i'm iterating through Family instances.
-RK
Replies (7)
Message 2 of 8
IbrahimNaeem
// doc is the current document in the revit session
foreach( Element e in Elmnts)
   String content = doc.GetElement(e.Id).LookupParamater("GetParameterValue2").AsValueString();
Message 3 of 8
Thanks Ibrahim
for your reply.
-RK
Message 4 of 8
IbrahimNaeem
@Anonymous if this solved your problem so kindly mark it as answer so others can follow if they reach out this post.
Thanks, Ibrahim Naeem
Message 5 of 8
Hi, ibrahim
having an error that snap attached here.
-RK.
Message 6 of 8
IbrahimNaeem
Alright, this depends on the type of the parameter which name is written here so sometimes .AsValueString() works , other time .Asdouble() works and so on, so try to cast it with these different methods until you get the right method to go with.
Message 7 of 8
Revitalizer
it seems that you just want to get the elements' IDs.
That's just: yourElement.Id.IntegerValue
Are you sure your parameter is named like a function, "GetParameterValue2" ?
The Null exception indicates that the given Element does not have such a parameter.
Also, if your Element does not have the desired parameter, it may be that it is attached to the Element's ElementType.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 8 of 8
Revitalizer
the method to use depends on the parameter's StorageType, I think ?
So no need to test all variants...
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
