Get top and bottom for dimensions
larsTB09
larsTB09
Trying to add dimensions to section view trough API
1) Dimension for with has been added. But how do i get the top face and bottom face to get a height dimension?
2) is it possible to add a second layer to show the location of the family on top of the beam? if yes, how do i snap the dim line to the family instance?
            var selectedBeam = uidoc
                .Selection
                .GetElementIds()
                .Select(doc.GetElement)
                .OfType<FamilyInstance>()
                .FirstOrDefault();
            var beamFaces = GetSolids(selectedBeam)
                .SelectMany(x => x.Faces.OfType<PlanarFace>())
                .ToList();
            var view = getview;
            var leftFace = beamFaces
                .FirstOrDefault(x => x.ComputeNormal(UV.Zero).IsAlmostEqualTo(-1 * view.RightDirection));
            var rightFace = beamFaces
                .FirstOrDefault(x => x.ComputeNormal(UV.Zero).IsAlmostEqualTo(view.RightDirection));
jeremy_tammik
To answer your first question, selecting top and bottom face: similar to your code for right and left face, pick the two faces whose normal vectors point up (Z direction, (0,0,1)) and down (-Z, (0,0,-1)) respectively.
