Get Space's Level Height
I'am trying to get specified space's level height.
on the image, a space's room height value is 2800.
i want to get value 3920 (space's level bottom to top height?)
help me.
jeremytammik
Hi.
I would suggest taking a look at the Space.ClosedShell property.
It will give you the 3D volume of the space.
Here is an example of using it to display the 3D volume of rooms:
http://thebuildingcoder.typepad.com/blog/2011/12/using-avf-to-display-intersections-and-highlight-ro...
On second thoughts, it might be simpler still to query the space for its bounding box.
Then you can just subtract the Z coordinate of the minimum from the maximum to get the height you are after.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
