Get/Set Split Section in ViewSection with API
mehdi.blanchard
mehdi.blanchard
Is it possible to Get and Set the ViewSection split shape with the API?
Split ViewSectionSplit ViewSection
ViewSection section = view as ViewSection;
ViewCropRegionShapeManager cropMgr = section.GetCropRegionShapeManager();
IList<CurveLoop> loopList = cropMgr.GetCropShape();
The single CurveLoop in the list has just 4 lines, which seems to be just the main frame of the section
bool split = section.IsSplitSection();  // returns false but I was expecting true
int nb = cropMgr.NumberOfSplitRegions; // return 1, was expecting at least 2
I haven't seen anything in the ElevationMarker class either.
Any help would be much appreciated...
bhprest
To my knowledge, what you are looking for is not exposed through the API.
"SplitRegions" in this context actually refers to the ability to split the VIEWPORT into separate portions (The UI for this feature is the zig-zag at the mid point of a viewport cropbox). Very confusing, and not all that helpful, since the API doesn't give us access to actually shift those regions once they're split.
