Can I use a Curve with FilteredElementConnector() and WherePasses()?
willjbird
willjbird
Hi there,
As the title says, can I use a curve/line as the ElementFilter for WherePasses() in an FilteredElementCollector()? It seems like I can't. I've created an Outline from the start point and end point of the curve, then created a BoundingBoxIntersectsFilter from the Outline but no elements are returned. All elements are returned when WherePasses() is not used as per the expected behaviour so no issues there.
Context:
I am projecting a curve from a point of a certain length, and I want to retrieve elements (well, the first element) that the curve passes through. Is this possible using FilteredElementCollector or should I be using another technique?
I've attached a screenshot of a visualization using Dynamo to show what I'm trying to do...
Thanks!
willjbird
Thanks for the response.
Turns out my whole issue I was not sending the correct Document to FilteredElementCollector but fixing that has fixed my issue.
However, reading your link has provided me with very valuable information I hadn't considered so thanks for that!
Cheers
willjbird
Hi all
Just for any future reference, a better way to do this I've found is using ReferenceIntersector().
Cheers
