- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
I am developing a plugin for Revit (version 2024/2025) and facing difficulties retrieving the absolute coordinates of the Base Point for linked models using the Revit API.
So far, I have tried multiple approaches to access this information:
- Used FilteredElementCollector with BuiltInCategory.OST_ProjectBasePoint and BuiltInParameter.BASEPOINT_*, but the values returned are always 0.0 or incorrect.
- Explored using the Transform of linked models to calculate the global coordinates, but the results did not match the expected absolute Base Point.
- Tried methods such as BasePoint.IsShared and other parameters, but the values retrieved were still inconsistent.
- Checked various suggestions from forums and the official Revit API documentation, but I couldn’t find a solution that worked for this specific need.
Goal:
The goal is to:
- Retrieve the absolute Project Base Point for each linked model within the global context, similar to what Revit displays in the project properties.
Question: Is there a specific or less conventional approach to retrieve the Base Point of linked models using the Revit API? Am I missing a crucial configuration or detail that would allow this?
Bruno Senna | Architect | BIM Manager | 18 years in BIM
If this solved your issue, please mark it as "Accept as Solution" so others can find it too. Kudos are always appreciated!
Resolveu sua dúvida? Clique em "Aceitar solução" para ajudar outras pessoas a encontrarem a resposta.
Developer Advocacy and Support +
