Get parent of a part in a linked model
a.sabatier
a.sabatier
Hi
I've created a part from a linked file and I'm trying to get the parent of that part.
I found that code that work when the parent is in the same document that the part but it returns "-1" when the parent is in the linked document.
Document documentlie = doc;
            //On crée la variable pour le document lié.
            foreach (Document dmt in uiapp.Application.Documents)
                if (dmt != doc) documentlie = dmt;
Element elt;
Part elementpart = elt as Part;
ICollection<LinkElementId> lIds = elementpart.GetSourceElementIds();
LinkElementId lId = lIds.First<LinkElementId>();
ElementId parentElementId = lId.HostElementId;
TaskDialog.Show("parentElementId", parentElementId.ToString());//return the right id when the parent is in the same file and "-1" when it's in a linked document
Thanks for your help.
Alexandre
jeremytammik
Dear Alexandre,
Thank you for your query.
GetSourceElementIds returns the ids of the elements from which a Part has been created by the PartMaker. There may be more than one source only if a merge is involved somewhere in the history of the Part.
In order to use it with a linked document, you probably have to check the LinkElementId lId first and see whether it represents a linked or local id.
As far as I can tell from the documentation, the HostElementId is designed to return -1 (representing an invalid element id, ElementId.Invalid) for linked elements.
For linked elements, you have to use the LinkedElementId property instead.
Look at the documentation of the LinkElementId members:
https://apidocs.co/apps/revit/2019/dccd1367-b891-92f1-f0d2-ece20af2b0cc.htm
  • HostElementId - The id of the element in the host, or invalidElementId if there is a link.
  • LinkedElementId - The id of the element in the link, or invalidElementId if no link.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
a.sabatier
Thanks Jeremy
I just changed
with
ElementId parentElementId = lId.LinkedElementId;
and it works.
Alexandre
jeremytammik
Lucky you!
And lucky me, for being able to guess the answer so easily  🙂
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
