Get ParameterType from ParameterId in Schedule
Message 1 of 8
Hi
I have a schedule and I can get ParameterId for every field. Now I need to retrieve ParameterType from ParameterId.
How can I do that?
Best
Replies (7)
Message 2 of 8
Sean_Page
I think you need to get the Internal Definition then use that to get the ParameterType.
https://www.revitapidocs.com/2020/e08c6586-26b2-2c2b-a699-3d4186dc3393.htm
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
Message 3 of 8
SamBerk
But how can I get the Internal Defenition from a PrameterId?
Message 4 of 8
lukaskohout
You can try this:
ParameterElement pe = doc.GetElement(yourParameterId) as ParameterElement;
Definition d = pe.GetDefinition();
ParameterType pType = d.ParameterType;
Hitting Accepted Answer is a Community Contribution from me as well as from you.
Message 5 of 8
SamBerk
Thanks @lukaskohout
It looks like your solution only works for Project Parameters or Sheard Parameters, is there any way to get the parameter definition of a built-in parameter?
Message 6 of 8
lukaskohout
And what you get when you call Document.GetElement(ElementId elementId) on the built-in parameter?(I have no Revit available right now)
Can you get anything else from the schedule than ElementId? Can you get the element with that parameter?
Message 7 of 8
SamBerk
it returns: null
i want to know if there is a way even if i don't have any element using this parameter
Message 8 of 8
lukaskohout
Well I do not know about anything for that. I always use shared parameters, and also mostly there is some element in the schedule.
It is well described here as well:
https://forums.autodesk.com/t5/revit-api-forum/getting-parameter-information-from-a-schedule/m-p/680...
Long story short, you need an element with given builtin parameter to get its definition.
