Get Material's Element
Hi !
I would like to get the material's of somes of my element.
I search on the web to get this, but it's doesn't work with everything.
I tried this :
ElementId id = e.get_Parameter(BuiltInParameter.MATERIAL_ID_PARAM).AsElementId();
if (id != null)
    Material mat = m_doc.GetElement(id) as Material;
But it's doesn't work with floor tile or cope.
Do you have something to accomplish what i want ?
Maxence
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
To get the material,
Element e ;
 FootPrintRoof FPR = e as FootPrintRoof;
foreach(ElementId Mat_id in FPR.GetMaterialIds(false))
                            Material M = doc.GetElement(Mat_id) as Material;
 Here,
If GetmaterialIds() is set to false then paint material wont be included
If GetmaterialIds() is set to true then paint material will be included
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Hi @naveen.kumar.t,
First, Thanks for reply !
Unfortunately, it's give me the same result as mine code.. I didn't get the material for the floor..
What I want to get is the same result as when i do : "nomenclature of material -> floor -> material name"
Maxence
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
Are you trying to get the materials from the floor??
I tried the code that i suggested and it works fine for me
could you please provide some screenshots of floor details to recreate the issue?
(Here your files are not confidential)
Naveen Kumar T
Hi !
I just figured out that my last reply didn't send.
So I had work on this case, and here what i found :
HostObject FPR = e as HostObject;
                    Type tp = FPR.GetType();
                    CompoundStructure structure = null;
                    Debug.WriteLine(tp.Name + "\n");
                    switch (tp.Name)
                        case "Wall":
                            Wall wall = e as Wall;
                            structure = wall.WallType.GetCompoundStructure();
                            break;
                        case "Floor":
                            Floor floor = e as Floor;
                            structure = floor.FloorType.GetCompoundStructure();
                            break;
                        case "FootPrintRoof":
                            FootPrintRoof roof = e as FootPrintRoof;
                            structure = roof.RoofType.GetCompoundStructure();
                            break;
                        case "Fascia":
                            Fascia fascia = e as Fascia;
                            structure = fascia.FasciaType.GetCompoundStructure();
                            break;
                        default:
                            structure = null;
                            break;
                    Material material = m_doc.GetElement(structure.GetMaterialId(0)) as Material;
It's working find, but i don't know if I could simplify the code (to don't list all Type)
