05:06 AM
I think there is an issue with the "PickObject" process.
Steps to reproduce :
- Select any view with "pickable" objects.
- Open the "Visibility/Graphic window" and keep it opened as a floating window.
- Launch a command (for example within an addin) that calls "PickObject" to select a "pickable" object.
- The picking process starts ...
At that point, you cannot select any object in the view (despite passing the picking filtering test).
You cannot press ESC to abort the picking process.
You cannot close Revit.
You cannot close the Visibility/Graphic window by its buttons.
Only thing you can do is close "Visibility/Graphic window" by ALT+F4, but then, the picking process is aborted without firing any exception.
