Get location of executing dll
Dale.Bartlett
2,481 次查看
5 条回复
1 条消息(共 6 条)
Dale.Bartlett
I am creating a new post as the one I appended is old and marked solved:
The solution accepted here does not work for 2017. It returns the location of the .addin file, not the location of the executing dll which is in a .bundle sub-folder. I have only just picked up that my support help files are not being found, although were previously. Has there been a change for 2017? I have also tried various suggestions with no success. In fact they return the same.
public static string GetDLLFolder()
            string codeBase = System.Reflection.Assembly.GetExecutingAssembly().CodeBase;
            UriBuilder uri = new UriBuilder(codeBase);
            string path = Uri.UnescapeDataString(uri.Path);
            return Path.GetDirectoryName(path);
Thanks, Dale
______________
Yes, I'm Satoshi.
0 个赞
已接受的解答 (1)
2,482 次查看
5 条回复
回复 (5)
2 条消息(共 6 条)
jeremytammik
已接受的解答
Dear Dale,
I don't think you need that codebase stuff.
I just use:
      Assembly exe = Assembly.GetExecutingAssembly();
      string path = exe.Location;
That returns the full pathname of the executing DLL assembly.
You can run
on that to extract just the directory name.
For instance, I use that in the CNC export add-in:
https://github.com/jeremytammik/ExportCncFab
https://github.com/jeremytammik/ExportCncFab/blob/master/ExportCncFab/App.cs#L61-L65
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
3 条消息(共 6 条)
Dale.Bartlett
Well I'll be hornswoggled. I thought that would return Revit.exe. Simpler is better. Thanks again. Dale
______________
Yes, I'm Satoshi.
0 个赞
4 条消息(共 6 条)
jeremytammik
Dear Dale,
Thank you for your appreciation and glad I could help.
Cool word, hornswoggled. Never heard it before.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
0 个赞
5 条消息(共 6 条)
Dale.Bartlett
And again for completeness... admission of my own stupidity. I was taking Path.GetDirectoryName() of the result, hence stepping back one level. Dummkopf.
______________
Yes, I'm Satoshi.
0 个赞
6 条消息(共 6 条)
Sean_Page
One note I'd add here is that if you are using Path.Combine make sure you don't put the "\" before the second path. I just about pulled my hair out trying literally 8-10 solutions for this only to realize it was the Combine that wasn't working correctly.
string dir = Path.GetDirectoryName(Assembly.GetExecutingAssemlby().Location)
//Bad:
Path.Combine(dir,@"\path2\file.xml")
//Good:
Path.Combine(dir,@"path2\file.xml"
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
0 个赞
