Get links in active document
ottosson_mathias
ottosson_mathias
I want to get all the linked files of the active document. But when I use a FilteredElementCollector with OfClass RevitLinkType I get all opened documents and their linked files! I only want the linked files of the current document. Not the the open document, just links 🙂
var links = new FilteredElementCollector(document).OfClass(typeof(RevitLinkType));
If not possible, how can I determine if the RevitLinkType in my filteredElementCollector is from the current document?
Thanks!
jeremytammik
Does this previous thread answer your question?
https://forums.autodesk.com/t5/revit-api-forum/find-revitlinks-is-loaded-or-unloaded/td-p/6819396
Jeremy Tammik
Developer Technical Services
The Building Coder
ottosson_mathias
Thanks Jeremy, it helped med to continue my search where I found this post which did exactly what I needed: https://forums.autodesk.com/t5/revit-api-forum/getlinkdocument-broken-in-2020/m-p/9385210.
Is it just me or is it difficult to get good search results on this forum search?
jeremytammik
Thank you for the additional link.
I totally agree that it is difficult, and that applies to just about every search engine I know.
Typepad is much worse.
Google and DuckDuckGo seem to provide decent results.
I just implemented my own full-text search, and that is not perfect either, as it stands now:
https://thebuildingcoder.typepad.com/blog/2020/09/optimising-parameters-and-full-text-search.html
Maybe you really need a bit of natural language processing (NLP) to be able to achieve really good functionality.
And with the speed at which that technology is currently advancing, I think much better results than we are used to should be achievable today without too much effort.
Jeremy Tammik
The Building Coder
