Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Get preview image of a view in Bitmap
3 REPLIES 3
1054 Views, 3 Replies
I would like to get a good view of an element in a document in Bitmap format. How would I go about doing this? I need it in Bitmap format because I would like to put it in winforms, showing a preview of the element.
I've checked out doc.ExportImage but that does not return a Bitmap and instead saves the file somewhere else.
I've also looked at elemType.GetPreviewImage, but the element I am looking at has no preview image.
Thanks in advance.
Labels (1)
3 REPLIES 3
jeremytammik
Since the two methods you mention are what is currently offered by the Revit API, I would suggest performing some research to find out how you can use them. It might be a long time before any other options crop up.
You could use ExportImage and then process to resulting file to retrieve a bitmap from that.
Alternatively, you could research how to ensure that GetPreviewImage does indeed return a suitable result.
Here are some examples showing how it can be used:
Jeremy Tammik
Developer Technical Services
The Building Coder
in reply to: jeremytammik
Alright got it thanks.
Since those are the only two options, I'll export the image into a temporary location, then load them into Bitmap.
jeremytammik
Way to go!
Jeremy Tammik
The Building Coder
Rail Community
