Get Linked View of Linked Document
nicolas.calvi
Message 1 of 9
nicolas.calvi
I would like get the "Linked View" name of a "Linked Revit Document" with Revit API (2020). I success to get the RevitLinkInstance of docuements, but in this instance I don't find the "Linked View" name.
Anyone can help me for this point ?
Thanks šŸ™‚
@Anonymous
Replies (8)
Message 2 of 9
Sean_Page
Once you have the LinkInstance you'll need to get the LinkType, then call GetLinkDocument().
            Document linkDoc;
            using (FilteredElementCollector rvtLinks = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RvtLinks).OfClass(typeof(RevitLinkType)))
                if (rvtLinks.ToElements().Count > 0)
                    foreach (RevitLinkType rvtLink in rvtLinks.ToElements())
                        if (rvtLink.GetLinkedFileStatus() == LinkedFileStatus.Loaded)
                            RevitLinkInstance link = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RvtLinks).OfClass(typeof(RevitLinkInstance)).Where(x => x.GetTypeId() == rvtLink.Id).First() as RevitLinkInstance;
                            linkDoc = link.GetLinkDocument();
Then get the views:
using(FilteredElementCollector linkViews = new FilteredElementCollector(linkDoc).OfCategory(BuiltInCategoris.OST_Views)
    foreach(View view in linkViews.ToElements())
        TaskDialog.Show("View Name",view.Name);
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
Message 3 of 9
nicolas.calvi
@Sean_Page
Thanks for the answer, but the result is not what I search to do.
I want to get the ACTIVE linked view selected, the red square on my capture.
My point is to list all active linked view, no all of them.
Message 4 of 9
AndrewButenko
Have you found a solution?
Message 5 of 9
nicolas.calvi
No we don't find any solution for that. Generaly, Revit API is very poor and not usefull for many scenario.
Message 6 of 9
AndrewButenko
Hi!
Maybe I'm solving a slightly different problem, but it's enough for me to get the view that is stored in the settings as in the screenshot. Maybe someone knows how to get it?
Message 7 of 9
Sean_Page
Looking into this further now that I better understand the request, I do not believe this functionality is exposed in the current API and therefore you won't be able to get the value programmatically.
Message 8 of 9
AndrewButenko
Maybe somebody will come in handy. I was solving the problem of getting visible elements from a linked file.  This  article helped me.
Message 9 of 9
g_sicre
Hi All,
this functionality is avialable from Revit 2024 onwards. There is a new class called "RevitLinkGraphicsSettingsto override display of a Revit link in a view. You can access these settings from a view using the method ".GetLinkOverrides()".
I hope this helps.
Cheers,
German
