Get Linked Elements that Appear on Schedule Revit API
Using the Revit API (2017 and above), is there any way to get a list of linked elements that appear on a schedule (including filters, phase filters, etc).
Currently, if you query a ViewSchedule using the FilteredElementCollector, it will return N Elements (e.g. Windows, Doors, FamilyInstance) and M RevitLinkInstances. However, the RevitLinkInstance does not list out the actual Element that appears in the linked model. Is there a way to query a RevitLinkInstance in the scope of a ViewSchedule? Or a similar solution?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
You can get all the elements in Linked Document by using the below code
 RevitLinkInstance RLI;
                    foreach(Document D in app.Documents)
                        if(D.IsLinked)
                            FilteredElementCollector FamilyInstances = new FilteredElementCollector(D).OfClass(typeof(FamilyInstance));
                            IList<Element> LinkedElements = FamilyInstances.ToElements() as IList<Element>;
                            foreach(Element element in LinkedElements)
                                //Do something
For creating ViewSchedule refer the following Link
Viewschedule API
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thanks for your reply. Unfortunately, the method of provided returns ALL elements from that Linked Instance. What I am looking for is only the linked instances that are contained within the ViewSchedule (e.g. PhaseFilters, ScheduleFilters, DesignOption visibility, etc).
callumf
Hey Jacob,
I have managed to get it to work by passing the Schedule Id to a new fileteredElementCollector like this:
schedule = doc.ActiveView
scheduledElements = list(FilteredElementCollector(doc, schedule.Id))
allElements = []
for element in scheduledElements:
    if element.Category.Name == 'RVT Links':
        linkedElements = list(FilteredElementCollector(element.GetLinkDocument(), schedule.Id))
        for linkedElement in linkedElements:
            allElements.Add(linkedElement)
    else:
        allElements.Add(element)
for element in allElements:
    print element
Let me know if that worked for you aswell
