Get Level Elevation From selected windows form combobox
zrodgersTSSSU
zrodgersTSSSU
So im trying to get the elevation of the level that i select in my windows form. I have it populating all the levels but now i cant figure out how to get the level elevation back.
CODE IN FORM:
CODE IN SCRIPT:
i just need the elevation from the selected level. Thanks ahead of time for any help!
jeremy_tammik
You are passing in the level name as a string to the document GetElement method.
That will not work. GetElement expects either an ElementId or a UniqueId argument:
https://www.revitapidocs.com/2021.1/8760be74-50fd-6809-aec6-3cb168d03ea5.htm
The latter is represented by a string, so GetElement tries to interpret your level name as a string.
You need to store either the level element id or unique id in your combo box as well.
You can attach it as additional data to each combo box entry.
zrodgersTSSSU
Thank you for your response. This is what ended up working for me.
FORM:
COMMAND:
