Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Get Hanger information from Options tab
3 REPLIES 3
ThanhPhanz
310 Views, 3 Replies
ThanhPhanz
From Hanger, I can get information in the Dimensions tab using FabricationPart.GetDimensions, but I can't find any way to get information in the Options tab.
Does anyone have any way to get this information? Thanks!
3 REPLIES 3
jeremy_tammik
in reply to: ThanhPhanz
jeremy_tammik
Don't know off-hand... I asked the development team for you.
jeremy_tammik
jeremy_tammik
They reply: unfortunately, the fabrication part options are not yet exposed in the Revit API. For now, you may be able to access options via the Fabrication API in CAM/EST after exporting as MAJ. Also, if all you need is to report the option values, you could use the Revit Fabrication Extensions add-in to create a report that displays option values, or create an export that writes them to a file.
ThanhPhanz
in reply to: jeremy_tammik
ThanhPhanz
I'll try the add-in. Thank you
