Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Get grids form PickObjects Selection
3 REPLIES 3
luisdavid.mena
597 Views, 3 Replies
luisdavid.mena
Hello
How can I get Grids from a List of Elements that I got with PickObjects method?
IList<Element> elemen_x = new List<Element>();
Selection sel = uidoc.Selection;
var axis_x = sel.PickObjects(ObjectType.Element).ToList();
foreach(Reference e in axis_x)
	var ele = doc.GetElement(e);
	elemen_x.Add(ele);
Hello
	elemen_x.Add(ele);
Tags (2)
Labels (1)
3 REPLIES 3
RPTHOMAS108
Sean_Page
in reply to: luisdavid.mena
Sean_Page
If you only want grids you can use the ISeletionFilter.
https://www.revitapidocs.com/2015/8038c1e1-262e-5d25-c065-b75b9ba98603.htm
Or you can use if check to see if it's a grid:
	If(doc.GetElement(e) is Grid grid)
	    elemen_x.Add(grid);
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
	    elemen_x.Add(grid);
luisdavid.mena
Thanks @RPTHOMAS108  . It was indeed the casting to Grids. Also what you suggest @Sean_Page  is very usefull for me!
