Get Geometry from Family Symbol
Message 1 of 8
Hi Guys,
How can I get the geometry from a Family Symbol that is loaded in the document?.
When I check the familiy via the Revit Look Up add-in it seems not to return anything. In addition, whenever I try something like:
 if (!furniture.IsActive) furniture.Activate();
GeometryElement geoEl = furniture.get_Geometry(m_options);
geoEl is always null
Any tips would be great.
Nicholas
Replies (7)
Message 2 of 8
jeremytammik
Maybe your furniture is invisible? What do you have in your options? The call you show will normally not return null.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 8
Hi Jeremy,
thanks for your reply. Yes, I don't see the furniture in the model, I can only select it in the project browser tab under the generic model category. As for the m_options I set is as:
 m_options.IncludeNonVisibleObjects = true;
I have run the debugger and and geoEl is always null
Message 4 of 8
Moustafa_K
hi,
to get geometry of a family instance, you need to look for geometry instance and not geometry element, try the below code i didn't test it, but i think it will do the job
List<GeometryInstance> ginsList = furniture.get_Geometry(m_options).Where(o => o is GeometryInstance).Cast<GeometryInstance>().ToList();
foreach (GeometryInstance gins in ginsList)
    foreach (GeometryObject ge in gins.GetInstanceGeometry())
     // your magic here
hope that helps
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Message 5 of 8
jeremytammik
Well, if you do not see the furniture in the model it may not have any geometry. Families can be user defined, and you can define a family that has no geometry. So everything is working as expected, afaict.
Jeremy Tammik
The Building Coder
Message 6 of 8
Hi @Moustafa_K ,
Your code will thorough a null reference exception, remember that
is always returning null
Message 7 of 8
Hi @jeremytammik
The family symbol does have geometry
Only when I place a family instance via the NewFamilyInstance() method I am able to see other properties in the properties tab when I select the family, as well having access to the geometry.
I guess this is only available once the instance is placed in the document?
Is there a way to get access to this information beforehand?
Nicholas
Message 8 of 8
FAIR59
You have to check, if the familysymbol is active. If the symbol is active the geometry is accessible
FamilySymbol symbol;
if (!symbol.IsActive) symbol.Activate();
Maybe you need a document.regenerate() after .
In the options you can specify the DetailLevel. Try setting the detaillevel to ViewDetailLevel.Fine.
