Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Get FilterElement Elements
2 REPLIES 2
lezsoft
417 Views, 2 Replies
Hi everyone...
I need to select all elements of a specified filter, created by the user in Revit (the ones you see in Visibility/Graphic Overrides -> Filters).
I got all documents' filters using
FilteredElementCollector(myDoc).OfClass(typeOf(FilterElement))
 but now I can't understand how can I get connected elements from a FilterElement because there isn't a propriety or a method to do that in FilterElement class.
Can someone help me?
2 REPLIES 2
MattKincaid
in reply to: lezsoft
Use FilteredElementCollector.ToElements
RPTHOMAS108
I believe you are asking if there is a way to understand what Elements are affected by a FilterElement?
FilterElement is the base class for:
ParameterFilterElement & SelectionFilterElement.
Therefore, once you have cast to one of those types above you can use the below as appropriate:
ParameterFilterElement.GetElementFilter that will return a ElementFilter that can be used with a FilteredElementCollector.
Or
SelectionFilterElement.GetElementIds that will return a collection of ElementIds
Rail Community
