Get File Path for Raster Image
Message 1 of 13
I am trying to get the filepath for an inserted image.
Looks like RASTER_SYMBOL_FILENAME builtinparameter holds the value (see revit loop up below).
But I am not being able to get the value.
I am using the RevitPythonShell and Revit 2015. Below is the code I tried.
Questions:
- Is get_Parameter still the proper way to get the BIP value?
Found this method being used in several examples, including here, although it's an old post I think I remember seeing a deprecation msg about this method. I tried .looking for it using Parameter and iterating through GetParameters as as well.
- Is RASTER_SYMBOL_FILENAME what I should be looking for when trying to find the original img filepath?
Thanks you in advance
IronPython 2.7.3 (2.7.0.40) on .NET 4.0.30319.42000 (64-bit)
Type "help", "copyright", "credits" or "license" for more information.
>>> img = selection[0]
>>> img.Category.Name
'Raster Images'
>>> BIP = BuiltInParameter.RASTER_SYMBOL_FILENAME
>>> fname = img.get_Parameter(BIP)
>>> fname
>>> print(fname)
None
>>> fname = img.Parameter(BIP)
Traceback (most recent call last):
  File "<stdin>", line 1in <module>
TypeError: indexer# is not callable
Replies (12)
Message 2 of 13
jeremytammik
Maybe the parameter has not been set and really is null.
You can check that using RevitLookup as well.
Also, some parameter values cannot be retrieved, because they have more complex values that do not fit into the valid parameter data type list of integer, double, string or element id.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 13
Hi Jeremy
I did use revit look up, and the value I am looking for is present, and stored as a string.
(see previously attached image, bottom right quadrant)
Message 4 of 13
jeremytammik
Very weird... almost cannot be... maybe some Python weirdness... sorry, I have no idea.
I would suggest you create a reproducible case for this:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 5 of 13
Revitalizer
may it be that you try to get the parameter from the image instance ?
Obviously it is a type parameter, which is attached to the image's ImageType.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 6 of 13
You were spot on. Thank you so much @Revitalizer
Here here is a dumb follow up question. I am just starting to get learn the api.
What's the best/most direct method for getting the type of an instance?
I used the GetValidTypes, and it worked. Then I tried just the GetType, and get parameter methods were not available.
Thanks in advance.
>>> img = selection[0]
>>> img.GetValidTypes()
List[ElementId]([<Autodesk.Revit.DB.ElementId object at 0x000000000000002D [245115]>])
>>> for img_type in img.GetValidTypes():
...  print img_type
245115
>>> t = doc.GetElement(img_type)
<Autodesk.Revit.DB.ImageType object at 0x000000000000002E [Autodesk.Revit.DB.ImageType]>
>>> t.Category.Name
'Raster Images'
>>> img.Category.Name
'Raster Images'
>>> t.get_Parameter(BuiltInParameter.RASTER_SYMBOL_FILENAME)
<Autodesk.Revit.DB.Parameter object at 0x000000000000002F [Autodesk.Revit.DB.Parameter]>
>>> p.AsString()
'C:\\Users\\gtalarico\\Pictures\\Solid.jpg'  <<< UHUUU!
>>> img = selection[0]
[Autodesk.Revit.DB.Element]>
>>> img_type = img.GetType()
>>> img_type.FullName
'Autodesk.Revit.DB.Element'
>>> img_type.get_Parameter(BuiltInParameter.RASTER_SYMBOL_FILENAME)
  File "<stdin>", line 1, in <module>
AttributeError: 'RuntimeType' object has no attribute 'get_Parameter'
Message 7 of 13
jeremytammik
Message 8 of 13
Thanks!
So what is GetType() actually returning of not the Element type?
Message 9 of 13
Ps:
Here is the tool I'm working on
It's an image cropper!
https://www.dropbox.com/s/hb9zdm82kxx11pm/2016-08-26%2019-29-21.flv?dl=0
Message 10 of 13
jeremytammik
GetType has nothing to do with Revit.
It is part of the .NET framework, on the base Object class, and cannot be eliminated:
https://msdn.microsoft.com/en-us/library/system.object.gettype%28v=vs.110%29.aspx
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 11 of 13
Many thanks @jeremytammik . That makes perfect sense now.
I am coming from python and I am just getting started with .net. I have a long way to go! Smiley Indifferent
Here is demo of the final thing working. It's an image cropper for embeded revit images
https://vimeo.com/180429233?ref=tw-share
Message 12 of 13
michellem
Hello;
I have tried gui.talarico image cropper on a image that I copy/pasted from the architect's Revit file into our Revit file. Unfortunately, it failed with an error about "path not found". I check the image type and found that the path points to the architect's path for the image. And I do not have access to the original file. Is there a way to save the pasted image - via the API or the user interface - onto my hard drive?
I have tried to copy/paste the image from the Revit file into a Word document but that fails also. I think the reason might be that Revit copies onto the clipboard a Revit Image Object and not a generic Image Object.
Sincerely;
Michelle
Message 13 of 13
Revitalizer
if your ElementType is an ImageType,
what about "imageType.GetImage()"?
It returns a Bitmap object which in turn could be saved locally.
Rudolf Honke
Software Developer
Mensch und Maschine
