Get face from floor object
I'm creating a plugin wich compares point cloud with differents revit objects and i want to get all the face from a floor object. Because my plugin can create elevation point on a floor and so if it create 50 point on a floor i will get a lot of face to select, and so i would like to select the floor object and get all the face. But i Don't find any fonction or method to get thoses face.
if someone has an idea i would be happy
jeremytammik
Here is code to get the bottom face of a wall:
http://thebuildingcoder.typepad.com/blog/2009/08/bottom-face-of-a-wall.html
The exact same approach applies to a floor a well.
Please always search for existing solutions before raining a new question.
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks for your reply and i didn't saw this topic
I just have a problem. In yout code you use a type called "GeoElement" when I use it, Visual Studio Don't find thuis type and so i can't create my dll file.
jeremytammik
That code was integrated into The Building Coder samples in 2009 and continues living and being maintained there still:
https://github.com/jeremytammik/the_building_coder_samples
Look at the module CmdWallBottomFace.cs and all your answers will be answered in full.
Jeremy Tammik
The Building Coder
Perfect i found what i neededn thanks a lot
