Document Session ID
Document Session ID
tobias.floescher
Document Session ID
tobias.floescher
Hello
Sorry for my stupid question, can't find an answer. But I'm sure there is a way.
Is there something like a session id for open documents?
I would like to uniquely identify a Autodesk.Revit.DB.Document object, for example in the ViewActivated Event. This is needed while more than one document can be open at the same time in Revit. Because I hold some stuff in memory, I need to know to which document it belongs.
The DocumentPath as Id is not an option, because newly created documents have a zero string (could be occur more than one as well in a session)
Many thanks for hints
Tobias
jeremytammik
Dear Tobias,
As we all know, there are no stupid questions.
Sometimes people would be better served searching for an answer themselves before asking others. It seems to me you have already searched, with no fruitful results. Thank you for that. However, there is some information on this already out there, waiting to be found:
Every Revit project includes a singleton ProjectInformation database element. Every database element has a unique identifier. So, theoretically, you could use that to uniquely identify a project.
Unfortunately, if I create a project A, and then copy it for reuse in project B, the two ProjectInformation elements will have the same unique id, so this solution only works if you can guarantee that no such copy will ever be created:
https://thebuildingcoder.typepad.com/blog/2017/12/project-identifier-and-fuzzy-comparison.html#2
Here is a some further analysis of this situation:
https://the3dwebcoder.typepad.com/blog/2015/07/implementing-mongo-database-relationships.html#2
To address this, I suggested a different and safer solution using an extensible storage schema and a named GUID storage for project identification instead:
https://thebuildingcoder.typepad.com/blog/2016/04/named-guid-storage-for-project-identification.html
I hope these various thoughts and suggestions can help.
Please do let us know how you end up solving this.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
tobias.floescher
Hello Jeremy
Indeed, I searched before without a satisfying result.
I came to the same conclusion as your solutions. I was hoping there was something else 😉
Possibly use the combination of unique identifier and the file path, but this is not very elegant. I think I will end up in use the solution with extensible storage. maybe a second scheme, not the same as my plugin use for storing its data.
Thank's a lot for your answer
regards,
tobias
RPTHOMAS108
Some documents don't contain a path (yet to be saved ones).
Document.GetHashCode has served me well over the years. Mainly I use this in static variable to see if the current document has switched via the ViewActivatedEvent.
tobias.floescher
Ah very nice. thank you for that.
read the manual:
https://www.revitapidocs.com/2020/006a71c2-4393-e036-9987-14467342a7d3.htm
