Get curve from Reference Plane
diogo.vieiraBCKUL
Message 1 of 10
diogo.vieiraBCKUL
I would like to get the curve from a selected Reference Plane, but it isn't working. Could anyone help?
My code:
		public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
			UIApplication uiapp = commandData.Application;
			UIDocument uidoc = uiapp.ActiveUIDocument;
			Document doc = uidoc.Document;
			Reference reference=pickGridsExtent(uidoc);
			var refPlane = doc.GetElement(reference.ElementId) as ReferencePlane;
			Curve refCurve = refPlane.Curve;
			return Result.Succeeded;
Code from pickGridsExtent(uidoc):
		public Reference pickGridsExtent(UIDocument uidoc)
			ISelectionFilter selFilter = new SelectionFilter.SelFilterRefPlane(); //Selection Filter of Reference Planes
			Reference reference = uidoc.Selection.PickObject(ObjectType.Element, selFilter);
			return reference;
Replies (9)
Message 2 of 10
Omar_Amen
Hi @diogo.vieiraBCKUL,
a fast simple way I use when I want to get any elements (childs) that depends on another element (parent) is:
doc.Delete(ElementId parantID );
it returns a list of deleted elements (parant + childs), I call it inside a transaction then after retrieve and store the list of deleted elements, I rollback the transaction
may you give it a try, it may help!
Message 3 of 10
diogo.vieiraBCKUL
Uhm, I only want to get a curve from a Reference Plane...
Message 4 of 10
jeremy_tammik
What curve are you expecting to get?
You can place any number of curves in a reference plane.
Furthermore, I see no method or property named `Curve` on the ReferencePlane class, so I do not see how you can compile your sample code snippet, or what you expect that statement to return.
Message 5 of 10
Omar_Amen
Dear @diogo.vieiraBCKUL ,
I snooped a reference plane using Revit lookup Add-in and found those 2 points of the referencePlane curve
so you can get the 2 points and if you need a curve you may create a line-curve using the points
try this code :
                Reference reference = pickGridsExtent(uidoc);
                XYZ sp = refPlane.BubbleEnd;
                XYZ ep = refPlane.FreeEnd;
                Curve c = Line.CreateBound(sp, ep) as Curve;
Message 6 of 10
diogo.vieiraBCKUL
I would like to transform Reference Plane into a curve or at least, make it assum Curve properties, so I could use SetCurveInView.
Message 7 of 10
Omar_Amen
Hi Jeremy, I think he means the curve of creation of the reference plane!
Message 8 of 10
diogo.vieiraBCKUL
Thank you for replying, I ended up using your code, like this:
			IList<Reference> rList = pickDesiredGrids(uidoc);
			Curve c = Line.CreateBound(sp, ep);
			using (Transaction trans = new Transaction(doc, "Move Bubbles"))
				trans.Start();
				foreach (var item in rList)
					var grid = doc.GetElement(item.ElementId) as Grid;
					grid.SetCurveInView(DatumExtentType.ViewSpecific, doc.ActiveView, c);
				trans.Commit();
And I get this error:
Thank you once again @Omar_Amen.
Message 9 of 10
Omar_Amen
I've just tried it on a sample file and it gives the same error even with the original grid curve!
I made some search for this exception error and found some topic that had a solution for it, may you check the links:
-https://forums.autodesk.com/t5/revit-api-forum/grids-off-axis/td-p/7129065
-https://forum.dynamobim.com/t/grid-extents-alignment-based-on-crop-region/55538
I hope that will help!
Message 10 of 10
guillain.jolivet
I'm using something like this to create a detail line from curve from a reference plan
    // Get the reference
    // Get the plane from reference
    Plane plan = SketchPlane.Create(doc, reference).GetPlane();
    // Get the curve from the plane
    Curve curve = Line.CreateBound(plan.Origin, plan.Origin + 1*plan.XVec); // (or plan.YVec)
    // Create detail line in the model
    DetailCurve line = doc.Create.NewDetailCurve(doc.ActiveView, curve);
