Get center point of a Rebar Shape
kimanh96tb
kimanh96tb
Hi All,
I'm looking a way to get the center point of Rebar from a Rebar Shape (i remark this point in the picture).
In my project, i did:
protected XYZ GetRebarOrigin(Rebar rebar)
IList<Curve> curves = rebar.GetShapeDrivenAccessor().ComputeDrivingCurves();
if (curves != null && curves.Count > 0)
return curves.First().GetEndPoint(0);
return null;
but it isn't point that i want to get. What do i do to get this point?
Thank you!
jeremytammik
I recently implemented code to retrieve the centre lines of the rebar, the rebar curves:
https://thebuildingcoder.typepad.com/blog/2019/07/roadmap-rebar-curves-wizard-zip-and-more.html#3
It is available from The Building Coder samples:
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/C...
You can determine the desired centre point from the centre curve as you feel appropriate.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
