Get center bar of a Rebar Layout
Hi All,
I'm looking a way to get the center Rebar from a Rebar Layout (Maximum spacing). I need to get this element to get its Centerline to create a DetailLine in the same position.
Any thoughts?
Thanks in advance!
jeremytammik
I asked the development team for you...
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thanks @jeremytammik! I'll be very attent to hear from you.
Regards!
Hi @jeremytammik , by now I managed to do this:
double numBars = barra.NumberOfBarPositions;
                        double indice = 0;
                        // Si es Par
                        if (numBars % 2 == 0)
                            indice = (numBars / 2) - 1;
                        // Si es impar
                        else
                            indice = Math.Truncate(numBars / 2);
                        #endregion
                        #region SE CREAN LOS DETAIL LINES EN LA POSICION DE LA BARRA CENTRAL
                        if (numBars > 1)
                            IList<Curve> curva_patron = barra.GetCenterlineCurves(
                                true,
                                true,
                                true,
                                MultiplanarOption.IncludeOnlyPlanarCurves,
                                Convert.ToInt32(indice));
                            DetailCurve dc = doc.Create.NewDetailCurve(
                                doc.ActiveView,
                                curva_patron.First());
                            dc.LineStyle = fe_losa;
In my iteration, get the "indice" variable (index) as the number I want (the middle index), and using the GetCenterlineCurves with that index, I always get the first one and my detail line is created in this position.
What am I doing wrong?
Regards!
jeremytammik
Dear Jorge,
Thank you for your update and congratulations on the progress.
I heard back from the development team, and they say:
The property Rebar.NumberOfBarPositions will give us the number of bars in the set.
The Method Rebar.GetCenterlineCurves receives a barPositionIndex and will return the centreline curves for that bar.
I’m not sure what you mean by 'centre bar'; if in the set are 4 bars (indexes 0,1,2,3). It should be index 1 or 2?
  public IList<Curve> GetCenterlineCurves(
    bool adjustForSelfIntersection,
    bool suppressHooks,
    bool suppressBendRadius,
    MultiplanarOption multiplanarOption,
    int barPositionIndex)
What is missing in your code: GetCenterlineCurves will return the curves as they are positioned on the first bar.
You can obtain a transform which will move the curves into the desired position:
  RebarShapeDrivenAccessor accessor = rebar.GetShapeDrivenAccessor();
  Transform trf = accessor.GetBarPositionTransform(indice);
  // Now apply the trf on each curve obtained from calling GetCenterlineCurves()
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Hi @jeremytammik ,
Following your indication I made exactly what I needed. Here is a snippet of the code II'm using so it may help some else in the future and the visual representation of what I achieved!
                                true,
                                true,
                                true,
                        // Se lleva la curva a la posicion central
                        RebarShapeDrivenAccessor accessor = barra.GetShapeDrivenAccessor();
                        Transform trf = accessor.GetBarPositionTransform(Convert.ToInt32(indice));
                        Curve curva_trans = curva_patron.First().CreateTransformed(trf);
                            doc.ActiveView,
                            curva_trans);
Again, thanks a lot!
Regards.
