Get CenteLinesCurves from rebar
Hello, I´m a newbie in this area.
I´m trying to get the center lines curves from the rebar to create a detail line with the shape of the rebar.
I´m cannot find the method to do this operation.
Any help will be welcome.
This is my code, I´m stuck at this point.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.Attributes;
namespace CreateImageRebar
    [TransactionAttribute(TransactionMode.Manual)]
    [RegenerationAttribute(RegenerationOption.Manual)]
    public class ReinforcementDetail : IExternalCommand
        //Clase de filtro de selección
        public class RebarPickFilter : ISelectionFilter
            public bool AllowElement(Element e)
                return (e.Category.Id.IntegerValue.Equals((int)BuiltInCategory.OST_Rebar));
            public bool AllowReference(Reference r, XYZ p)
                return false;
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiApp = commandData.Application;
            Document doc = uiApp.ActiveUIDocument.Document;
            Reference pickedRef = null;
            Selection sel = uiApp.ActiveUIDocument.Selection;
            RebarPickFilter selFilter = new RebarPickFilter();
            pickedRef = sel.PickObject(ObjectType.Element, selFilter, "Seleccione una Armadura");
            //Obtener referencia
            Element el = doc.GetElement(pickedRef);
            Rebar myRebar = el as Rebar;
Mustafa.Salaheldin
Dear pipiyedu
I completed your code to accomplish the mission. Good luck.
using System;
using System.Linq;
using System.Text;
                return false;
            List<Curve> lc = myRebar.GetCenterlineCurves(true, true, false).ToList();
            return Result.Succeeded;
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Thank you! I´ll try it!
