Get CenteLinesCurves from rebar
06:44 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I´m a newbie in this area.
I´m trying to get the center lines curves from the rebar to create a detail line with the shape of the rebar.
I´m cannot find the method to do this operation.
Any help will be welcome.
This is my code, I´m stuck at this point.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.Attributes;
namespace CreateImageRebar
[TransactionAttribute(TransactionMode.Manual)]
[RegenerationAttribute(RegenerationOption.Manual)]
public class ReinforcementDetail : IExternalCommand
//Clase de filtro de selección
public class RebarPickFilter : ISelectionFilter
public bool AllowElement(Element e)
return (e.Category.Id.IntegerValue.Equals((int)BuiltInCategory.OST_Rebar));
public bool AllowReference(Reference r, XYZ p)
return false;
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
UIApplication uiApp = commandData.Application;
Document doc = uiApp.ActiveUIDocument.Document;
Reference pickedRef = null;
Selection sel = uiApp.ActiveUIDocument.Selection;
RebarPickFilter selFilter = new RebarPickFilter();
pickedRef = sel.PickObject(ObjectType.Element, selFilter, "Seleccione una Armadura");
//Obtener referencia
Element el = doc.GetElement(pickedRef);
Rebar myRebar = el as Rebar;
