Get bounding box from solid of a structural column is not accurate
heziTYJKR
heziTYJKR
Hi everyone,
I have an issue getting an accurate bounding box from a solid of structural columns only.
Following is an example of a few elements and the bounding box that was created from them (the bounding box is yellow):
Structural Column extrusion (you can see that the yellow bounding box is larger than the actual column):
A structural column with blend shape (this one is also inaccurate):
And just to check that it is not happening to any direct shape, I tried getting a bounding box for extrusion of structural framing and I got an accurate result:
So in other words: getting a bounding box from solid works for many kinds of shapes except for a shape created as part of a structural column.
Note: if I get a bounding box for those shapes using get_boundingbox(null) method then it works, but we want to have a unified and more accurate method for all the elements to obtain an accurate bounding box from the solid.
jeremy_tammik
I do not see the inaccuracy that you describe. Is my eyesight poor, or is the inaccuracy pretty small?
Remember: a bounding box is a bounding box. There is no guarantee that a bounding box is minimal. Never.
The main purpose of a bounding box is speed, not accuracy, and definitely not to be minimal.
heziTYJKR
Let me present it in more details, the red area is the difference between the received bounding box and the actual element:
It is 1/16" and it has an effect on our tools.
We need a precise accuracy and we do get it in most of the cases and this is the reason that we use the solid and not just the original get_boundingbox method.
The fact that it works for other kinds of direct shapes proves that something is wrong in this specific case.
jeremy_tammik
When you say "bounding box", I assume that you are using the Element BoundingBox property, i.e.., get_BoundingBox.
What issues is this causing?
As said, you can never assume that a bounding box is minimal, so, if this is causing an issue with your tools, I would recommend checking whether they are erroneously making this assumption. If they are, it might be safer to fix them.
heziTYJKR
When I say bounding box in the specific case of the solid, this is what I mean:
https://www.revitapidocs.com/2015/716fecd9-7d09-fa61-5c02-de714259a214.htm
The goal is to get a minimal bounding box and this is why we are working with the solid.
As I said, in most cases, it works.
After further investigation, we discovered that this happens if at least one of the corners is round.
I hope this also helps.
