Get Bottom Face of Door
I need to get the bottom face of a door (highlighted in the image below)
However, I have no idea of how one could do this. I have some experience of getting different faces on Walls, but I cannot translate it to Doors/Family Instances.
Thanks in advance!
RPTHOMAS108
likely bottom face with have the smallest Z value for face origin and have a normal similar to 0,0,-1.
Have a look in RevitLookup, there could be many bottom faces in family instances, so no standard way. Doors should be easy though because they are always vertical.
Choosing which face is the easy part, but how do I get all of the faces in the first place?
RPTHOMAS108
It is similar to extracting geometry from Walls only real difference is that unmodified FamilyInstances have a top level GeometryInstance that contains the geometry primitives. The process for modified (cut/joined) FamilyInstances is the same as system families such as walls.
There is a good example under Element.Geometry in RevitAPI.chm. This example extracts both Solids and Curves but you can take out the curves part.
For each solid you can then use Solid.Faces collection.
