Get Appsettings not app.config ?
a.burgaudeau
Observer Observer
a.burgaudeau
Observer
Observer
Hi !
I want to setup a logging service with Configuration file. With  Microsoft we must used inject dependency...
To do that I need "Getsection" in the AppSettings.json.
I follow this page : here
ServicesBuilder :
            services.AddLogging(loggingBuilder =>
                loggingBuilder.CodeFileLogger(options =>
                    Configuration.GetSection("Logging").GetSection("CodeFile").GetSection("Options")
                        .Bind(options);
AppSettings :
  "Logging": {
    "LogLevel": {
      "Default": "Debug",
      "System": "Information",
      "Microsoft": "Information"
    "CodeFile": {
      "Options": {
        "FolderPath": "Logs",
        "FilePath": "log_{date}.log"
      "LogLevel": {
        "Default": "Debug",
        "Microsoft": "Information",
        "LicenceManager.API.Controllers.Controllers": "Information",
        "LicenceManager.API.Controllers.Services": "Information"
Thx !
moturi.magati.george
Hi @a.burgaudeau,
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
I am not able to clearly understand your question but if you want to split your log data into different files, you can try to read here https://learn.microsoft.com/en-us/aspnet/core/fundamentals/logging/?view=aspnetcore-7.0
You can also use serilog package to achieve the same result as explained here https://github.com/serilog/serilog with a simple log splitting example here https://vmsdurano.com/serilog-and-asp-net-core-split-log-data-using-filterexpression/
  Moturi George,     Developer Advocacy and Support,  ADN Open
