Creating a circular column
ahmadkhalaf7892
ahmadkhalaf7892
Hi everyone, forgive me for asking but I am a newbie in Revit API.
I wanted to ask if there was any possible way so that we can create a new circular column in Revit API?
I don't know if it is possible, I have been checking the forum for such a topic, but I didn't get my answer.
I am still in the learning process and trying to understand how it works. Thanks
jeremy_tammik
Welcome to the Revit API.
Yes, certainly you can programmatically create a circular column.
However, you cannot succeed with that task without first understanding the manual process to achieve the same through the end user interface. It requires creating a family definition and defining family types.
I suggest that you learn how to perform this task manually through the end-user interface first. Once you have understood that process, you can look into automating it using the API.
Once you are well prepared for that, you can take a look at some important articles explaining the programmatic family creation process shared by The Building Coder:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.25
ahmadkhalaf7892
Hi Jeremy
Thank you for the guidance, from what I have read I first have to create the column Family manually and insert it into the Revit project so that I can add it using Revit API. This is the better approach, right?
Can the Revit API create a family from zero? I am asking for future purposes I am not intending to such an action now
jeremy_tammik
> have to create the column Family manually...
... or programmatically.
Yes.
Yes.
Here is an example of all three steps:
  • Create family definition
  • Load family into project
  • Place family instance
ahmadkhalaf7892
Thank you my dear , I will see what I can and learn
