Get app.VersionName in ControlledApplication Event?
How does one get the application in the event to call the VersionName?
Reference the bottom of the code:
var appver = ctrlApp.VersionName;
 using something
 namespace something
    public class ExtDbAppEventLogger : IExternalDBApplication
        public static ControlledApplication _cachedCtrlApp;
        //IExternalApplication Members
        public ExternalDBApplicationResult OnStartup(ControlledApplication ctrlApp)
            try
                _cachedCtrlApp = ctrlApp;
                _cachedCtrlApp.DocumentClosed += new EventHandler<DocumentClosedEventArgs>(CachedCtrlApp_DocumentClosed);
                return ExternalDBApplicationResult.Succeeded;
            catch (Exception ex)
                return ExternalDBApplicationResult.Failed;
        void CachedCtrlApp_DocumentClosed(object sender, DocumentClosedEventArgs e)
            using (StreamWriter sw = new StreamWriter(@"\\Server\files\log.txt", true))
                sw.WriteLine(appver);
Do I pass the application from the OnStartup as an arg in the call for the CachedCtrlApp_DocumentClosed?
_cachedCtrlApp.DocumentClosed += new EventHandler<DocumentClosedEventArgs>(CachedCtrlApp_DocumentClosed(ctrlApp);
CachedCtrlApp_DocumentClosed(object sender, DocumentClosedEventArgs e, ControlledApplication appver)
I am very new to C# and programming in general. I apologize if this is all way off base. Thank you for reading.
string xxx = _cachedCtrlApp.VersionName.ToString();
using System;
using System.IO;
using System.Windows.Forms;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
namespace MyNamespace
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
        #region Cached Variables
        #endregion
        #region IExternalApplication Members
            try
                _cachedCtrlApp.DocumentCreated += new EventHandler<DocumentCreatedEventArgs>(CachedCtrlApp_DocumentCreated);
                _cachedCtrlApp.DocumentOpened += new EventHandler<DocumentOpenedEventArgs>(CachedCtrlApp_DocumentOpened);
                MessageBox.Show(ex.ToString());
            string xxx = _cachedCtrlApp.VersionBuild.ToString();
            string yyy = _cachedCtrlApp.Product.ToString();
            using (StreamWriter sw = new StreamWriter(@"\\Server\log.txt", true))
                sw.WriteLine(DateTime.Now.ToString() + ", " + Environment.UserName + ", Closed, " + xxx + ", " + yyy + ", " + e.DocumentId.ToString());
        void CachedCtrlApp_DocumentOpened(object sender, DocumentOpenedEventArgs e)
                sw.WriteLine(DateTime.Now.ToString() + ", " + Environment.UserName + ", Opened, " + xxx + ", " + yyy + ", " + e.Document.PathName);
        void CachedCtrlApp_DocumentCreated(object sender, DocumentCreatedEventArgs e)
                sw.WriteLine(DateTime.Now.ToString() + ", " + Environment.UserName + ", Created, " + xxx + ", " + yyy + ", " + e.Document.PathName);
        public ExternalDBApplicationResult OnShutdown(ControlledApplication ctlApp)
            try
        #endregion
RPTHOMAS108
You can access version via UIApplication.Application.Version (you don't need to store UIControledApplication) you can get from event sender in a lot of cases.
Feel sorry for the guy that has to read log.txt here. Also should consider that this approach may cause some file access issues if you have multiple users all with this addin opening/closing/creating.
A tally system could be better for this:
Each user add-in writes a file to the network.
At the top of the file you assign an integer to each version number of Revit found to open i.e. each time Revit starts it looks through the versions already recorded and adds a new one if not found.
At the same time you store a table of events by that user e.g.
Ver, Revit2020, 0
Ver, Revit2021, 1
0 , 2 , 2,  8
1, 14, 14, 9
First column: if not a number is a definition of Revit version
First column: if a number is the version id
Second column: number of opening events
Third column: number of closing events (do we expect it to be different from number of opening I don't know)
Fourth column: number of creating events
This is more advanced logging it requires first reading the log and then replacing it. One file for every user means no file access violation exceptions (I don't expect you to read them all manually).
Since you are not recording dates then the information collected is almost the same. The only difference is sequence i.e. you will never know for sure close follows open for a version and what session that was in but are you really going to trawl through hundreds of almost identical lines (without timestamp) to find that out?
@RPTHOMAS108,
Thank you for your post! It is folks like you taking the time to lend a hand that makes the community amazing. Thank you for the mention of the file access issue. I will work out a solution for this next. I am working through a proof of concept for my first Revit add-in. It continues to grow and improve by the day. With the help of the community, I am confident the end result prior to launching it to several users will be good.
I am off to investigate the event sender that you mentioned can provide the needed access to get the properties. Stay tuned.
RPTHOMAS108
In the end the version properties you are looking for are actually found on:
Autodesk.Revit.ApplicationServices.Application
Senders of the below events were found to be:
DocumentClosed: sender = Autodesk.Revit.ApplicationServices.Application
DocumentCreated: sender = Autodesk.Revit.ApplicationServices.Application
DocumentOpened: sender = Autodesk.Revit.ApplicationServices.Application
(subscribed to within IExternalApplication however)
If you end up with UIApplication anywhere you can still get:
from
If you are dealing with UIControlledApplication you can get:
Autodesk.Revit.ApplicationServices.ControlledApplication
From
UIControlledApplication.ControlledApplication
Which contains same version properties
So largely not a problem getting at version properties from anywhere.
