Get all points from PointCloudInstance near a solid with tolerance
SONA-ARCHITECTURE
SONA-ARCHITECTURE
Hello
I'd like to know if it's possible to obtain a collection of points (from a PointCloudInstance) close to the whole of a solid?
I used CreateMultiPlaneFilter to create a set of planes from the BoundingBox of my occurrence but if my tube makes a bend or if my occurrence is a more complex geometry, I get back way too many points...
Thank you for your answers.
Pierre NAVARRA
SONA-Architecture.
http://www.sona-architecture.com
https://fr.linkedin.com/in/pierre-navarra-62032a107
jeremy_tammik
Yes, absolutely. I am afraid the Revit API will probably not be able to help you much in filtering individual points. The Revit API filters deal with higher-level BIM elements. For such fine-grained filtering, you will have to use other, more specialised tools. Maybe some of the point cloud libraries on GitHub will be able to help:
kubitTilo
You could try to get a mesh of the solid's faces using Face.Triangulate(), and then refine the points which are in the bounding box by calculating the distance of each point to the mesh. To handle computational complexity you might need to use suitable data structures for the mesh and points. So, lots of work, I guess...
Tilo Pfliegner
SONA-ARCHITECTURE
Hy @jeremy_tammik
Nice to read you 😊
Thanks for your answer and your links. Do you think it is possible to use those point cloud libraries in a plug-in project wich is using RevitAPI ?
I guess it's not possible to access RevitAPI objects like PointCloudInstance? I don't know if my question is very clear...
Pierre NAVARRA
SONA-Architecture.
jeremy_tammik
Sure it is possible. If you can find a library in .NET, it is very easy indeed. Of course none of those generic libraries will know anything whatsoever about the Revit API. So, you will have to implement code to extract the Revit data you wish to process and convert that to a format that the library understands.
The potree library has been mentioned here in the forum in the past:
Maybe you can find some useful hints searching this forum for potree:
SONA-ARCHITECTURE
Hi @jeremy_tammik
If I understand correctly, I retrieve the information from my clouds via PointCloudInstance Class and then, for example, I use potree to perform more manipulation on my points, right? (Like, for example, having the list of points all around a solid) We agree that potree won't allow me to modify the appearance of my clouds in Revit, for example?
By the way, thx also to @kubitTilo
Pierre NAVARRA
SONA-Architecture.
jeremy_tammik
Yes, exactly.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
