Generative Design doesn't respond. ConnectionRefusedError: [WinError 10061] No connection could be made because the target machine actively refused it
ozmenmur
ozmenmur
Hi All,
When I try to use Generative Design, it stucks and I can see a error as "ConnectionRefusedError: [WinError 10061] No connection could be made because the target machine actively refused it"
in refinery server log.
Could anybody help me?
jeremy_tammik
Is this a programming issue, or are you just using the GUI as an end user to drive this?
Afaict from your query and screen snapshot, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit or some other user interface. In that case, unfortunately, this is not the best place to ask such a question. Please note that this discussion forum is dedicated to programming Revit using the Revit API. You will probably get more optimal answers to a question like yours relating to product setup, optimisation, usage, best practices and other end-user support issues in one of the non-API Revit product support discussion forums instead:
I see that you log file mentions Dynamo in some shape or form; if it is a Dynamo issue, you might be able to get more help in the Dynamo forum:
