Generation model using Forge (Design Automation) makes elements invisible
IliaIvanov
Message 1 of 8
IliaIvanov
I have some troubles after Forge model generation. The main goal is to get rvt model from JSON.
I have tested my code with Revit API in Revit. It works nice. But when add bundle to the Forge app and got rvt result - I have faced with weird glitch. I can`t see any wall in the project, but walls exist. I have checked with lookupRevit and saw walls and ids.
The question is "How to make invisible walls be visible?"
I have attached the recording demonstrating my glitch.
Replies (7)
Message 2 of 8
jeremy_tammik
That sounds weird... interesting.
However, please note that this forum is dedicated to the Revit API pure and simple, running .NET add-in on the Windows platform.
Forge questions are better discussed under the dedicated Forge tags on StackOverflow:
https://forge.autodesk.com/en/support/get-help
I do not see any recording attached to this thread either, by the way.
In any case, I would suggest asking on StackOverflow. I can happily pick up the question from there once I see it.
Thank you!
Cheers,
Jeremy
Message 3 of 8
IliaIvanov
Thanks Jeremy for the quick reply. I have added link from youtube.
Message 4 of 8
jeremy_tammik
Thanks for the video.
I have no idea what could be causing this.
There are an almost infinite number of ways to control visibility and graphics of BIM elements in Revit.
Maybe you are making inadvertent use of that wealth of possibilities.
Maybe it depends on your template file, or other settings.
Message 5 of 8
IliaIvanov
I have checked filters, visibility&graphic settings, show hidden and etc. After selection all wall and copy them to the same place we are able to see these walls (copy of hidden). This is weird bug as I don`t know how I can make elements invisible without ability to make it visible again.
Message 6 of 8
IliaIvanov
if you are interested I can share my rvt project with hidden walls
Message 7 of 8
jeremy_tammik
Here are some discussions on invisible elements:
https://forums.autodesk.com/t5/revit-api-forum/newdimension-dimension-created-but-not-visible/m-p/63...
https://forums.autodesk.com/t5/revit-api-forum/copy-dimensions-from-a-view-to-another/m-p/7226217
I would suggest first of all searching for other, similar discussions and hoping for a hint from there.
Message 8 of 8
jeremy_tammik
Solved in the SlackOverflow thread:
https://stackoverflow.com/questions/66796225/generation-model-using-forge-design-automation-makes-el...
The problem was due to the walls being created in Phase 3, and the view displaying Phase 1.
