Generating Elements Dynamically
Hi everyone,
I am trying to programmatically create grids with the attached code fragment. This code fragment is now working fine, but the matter here is that the grids are all generated at one time when the command is completed.
Is there any way to dynamically generate grids one by one while the iteration still moving?
This is possible if I show a Message Box on each transaction, but this way I need to manually close the Message Box for every transaction then.
Looking forward for a solution
My code
ElementCategoryFilter categoryFilter = new ElementCategoryFilter(BuiltInCategory.OST_Lines);
IList<Element> allLines = new FilteredElementCollector(doc).WherePasses(categoryFilter).WhereElementIsNotElementType().ToElements();
foreach (Element e in allLines)
    LocationCurve locationCurve = e.Location as LocationCurve;
    foreach (Parameter param in e.Parameters)
        if (param.Definition.Name.Equals("Line Style") && param.AsValueString().Equals("Hz_Grid"))
            using (Transaction tran = new Transaction(doc, "Tạo Lưới"))
                Line line = Line.CreateBound(locationCurve.Curve.GetEndPoint(0), locationCurve.Curve.GetEndPoint(1));
                tran.Start();
                doc.Create.NewGrid(line);
                tran.Commit();
Thank you
Nguyen Duy Hoa
jeremytammik
Dear Nguyen Duy Hoa,
So yu want to refresh the screen during the execution of the command.
This topic has been discussed a couple of times by The Building Coder:
http://thebuildingcoder.typepad.com/blog/2014/06/refresh-element-graphics-display.html
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Dear Mr. Jeremy
A long awaited answer and yes exactly what I am looking for. It works as desired
It means the model elements are actually dynamically generated on each transaction but the view keeps pending during the execution
So, the remedy for this issue is just refreshing the active view during the execution
Thank you very much for a pertinent answer
Nguyen Duy Hoa
