03:03 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello All,
I'm using dynamo to generate sheets from excel (by using this link). I'd like to create an add-in for Revit that simulates the same functionality. I researched and found this solution that generates sheets from the CSV file. However, I'm not able to understand the steps to generate the sheets like the dynamo file does (please see the link).
I'm wondering if anyone could explain the steps so I could write a better code so, it could work like that dynamo file solution works. Thank you
