Generate 3D View Programmatically
Message 1 of 8
if i select imperial or metric template there is no 3DView listed in view by default(Revit 2015), so i want to generate 3DView programmatically,
how to achieve it.
Thanks in advance,
Regards
Kailash
Replies (7)
Message 2 of 8
jeremytammik
Dear Kailash,
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.37
Certainly you could have found this yourself?
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 8
Revitalizer
if you want to create default {3D}, you can use:
RevitCommandId commandId = RevitCommandId.LookupPostableCommandId(PostableCommand.Default3DView);
if (commandData.Application.CanPostCommand(commandId))
    commandData.Application.PostCommand(commandId);
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 4 of 8
Thank you Jeremy sir,
Below is the working code which you have already mentioned in Exporting Image and Setting a Default 3D View Orientation
i picked up this one
                     var direction = new XYZ(-1, 1, -1);
                        var collector = new FilteredElementCollector(Doc);
                        var viewFamilyType = collector.OfClass(typeof(ViewFamilyType)).Cast<ViewFamilyType>()
                          .FirstOrDefault(x => x.ViewFamily == ViewFamily.ThreeDimensional);
                        using (Transaction ttNew = new Transaction(Doc, "abc"))
                            ttNew.Start();
                            var view3D = View3D.CreateIsometric(
                                              Doc, viewFamilyType.Id);
                            view3D.SetOrientation(new ViewOrientation3D(
                              direction, new XYZ(0, 1, 1), new XYZ(0, 1, -1)));
                            ttNew.Commit();
Regards
Kailash Smiley Very Happy
Message 5 of 8
Thank you Revitalizer,
your posted code is also working, just i placed it in a proper location in my project.and done.
Regards
Message 6 of 8
BIM_S_S
it work when i open one document only
not working with multiple documents
Message 7 of 8
Revitalizer
yes, of course, it works with the active document.
The function simulates the user clicking the related button, as all the postable commands do.
Works as exspected, I would say.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 8 of 8
pccheung
Dear Revitalizer,
I have lines of code of about TaskDialog.Show() after the postable command. But i don't know why the taskdialog is executed before the postable command, what mistake did i make?
Moreover, I have create the default {3D} view with the postable command, how should I make the {3D} view active and set a section box on it?
I found that the postable command
