Hello All,
I apologize in advance for the lack of information in this post, but due to the nature of the issue, it is very difficult to gather useful data. I am curious to see how many other Revit users have encountered this same issue, as I am starting to fear that it may be a side-effect of the way I've been messing around with the Revit API. The issue is that, sometimes, when launching a document in Revit, the entire Revit UI suddenly becomes completely unresponsive after the document splash screen appears. All UI elements are frozen and the application can't even be closed without either canceling the Debug through Visual Studio or force-closing the application through Windows Task Manager. If I had to account for a frequency, I would say that this issue occurs about once every 12-15 document initiations. I also can't say that it's entirely confined to Revit 2017.2, as I believe I have encountered it in both 2016 and 2018, but I don't use them as frequently to be sure. It would make sense if this issue is unknown to Autodesk on some larger scale because it's definitely not a crash and therefore doesn't report the app failure back to the Autodesk Dev Team.
Thank You Very Much,
James M. Kerfoot
