Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Force my app to use assemblies in its folder
1 REPLY 1
305 Views, 1 Reply
Hi Dears,
i have some plugins for Revit each one in separated folder with its own & shared dll files like following
my apps in folders named            A                       B                          C
each folder contain in it            A1.dll                B1.dll                  C1.dll
                                                      A2.dll                B2.dll                  C2.dll
                                                       X.dll                   X.dll                   X.dll      =>     same files
                                                       Y.dll                   Y.dll                    Y.dll      =>     same files
                                                       Z.dll                   Z.dll                    Z.dll      =>     same files
Revit always loading x, y & Z from A folder and ignore the same files in folders B & C
apps B & C always using X, Y & Z from A folder even when using Assembly.LoadFile or AppDomain.Load (i can't use reflection over all my apps), I also change their version and its GUID but no effect
how to force Revit & my apps B & C to use only the dlls (X.dll, Y.dll & Z.dll) in its own folder not dlls with the same name from the first folder
many thanks in advance
Hi Dears,
1 REPLY 1
jeremytammik
jeremytammik
Afaik, you have to name the different flavours of X, Y and Z differently.
Afaik, if they are named the same, .NET will only load the first one and reuse that for the others.
https://thebuildingcoder.typepad.com/blog/2019/11/dll-conflicts-and-replicating-schedule-sort-order....
Jeremy Tammik
Developer Technical Services
The Building Coder
Jeremy Tammik
The Building Coder
