Focus problem in dockable window with hosted WebBrowser (IE) control
we have a dockable window which hosts a WebBrowser control. If the browser displays a form it's not possible to switch between the form fields (i.e. text fields) using <TAB> key. Everytime the <TAB> key is pressed the window looses the focus. A mouse click into every text field of the web form is necessary to fill the form.
Is it possible to prevent the focus switch? Or how can I hold the focus in the WebBrowser control?
Thommy
Aaron.Lu
An issue is reported to our engineering team,
however, It might be a WPF problem, like this http://stackoverflow.com/questions/8838888/c-sharp-webbrowser-tab-key, which is not solved yet..
Aaron Lu
Developer Technical Services
Autodesk Developer Network
