Fixture units dont update when Addin is running
nelsonhp3
Message 1 of 8
nelsonhp3
I'm creating an addin that needs the values ​​of Fixture Units for piping systems. However, when the system has an open end, the value of the Fixture Units is equal to zero in some parts.
I tried to create a subtransaction that adds cap to open ends and then deletes them (see image below). However, I realized that while adding the caps, the fixture units are not updated. How can I solve this problem?
Is there any way to update the fixture unit calculation by API?
Replies (7)
Message 2 of 8
RPTHOMAS108
Have you tried calling Document.Regenerate after adding the caps and then inspecting the parameter value? Regenerate is automatically called after a transaction completes.
Message 3 of 8
TripleM-Dev.net
Use TransactionGroup, and inside it call the various transaction.
Commit the Transaction and don't assimilate the transactionGroup at the end.
See if this is enough to get the correct values.
If values need to be written back to the Revit Database, do it in a seperate transaction AFTER the group is ended.
See a earlier post: refresh-after-every-pickobject
- Michel
Message 4 of 8
jeremytammik
Message 5 of 8
nelsonhp3
Thank you, it worked. This is how I made:
TransactionGroup endCapsRecall = new TransactionGroup(doc);
            Transaction endCaps = new Transaction(doc);
            endCapsRecall.Start("Transação temporaria");
            endCaps.Start("Colocar os end caps");
            foreach (PipingSystem ps in CollectorSystems)
                if ((ps.SystemType == PipeSystemType.DomesticColdWater || ps.SystemType == PipeSystemType.DomesticHotWater)
                    && ps.BaseEquipmentConnector != null && ps.BaseEquipmentConnector.Direction == FlowDirectionType.Out)
                    foreach (Element pp in ps.PipingNetwork)
                        if (pp is Pipe && PlumbingUtils.HasOpenConnector(doc, pp.Id))
                            PlumbingUtils.PlaceCapOnOpenEnds(doc, pp.Id, (pp as Pipe).PipeType.Id);
            endCaps.Commit();
            coldAndHotWaterSystems = createSectors();
            endCapsRecall.RollBack();
Just a note, I can't make it work with
using (Transaction endCaps = new Transaction()) {}
Message 6 of 8
TripleM-Dev.net
if I read the code correct the endcaps can all be edited in one transaction so the inner transaction would only be needed once.
I was in the understanding that each endcap needed to be edited and then read and the next and the next..
Try the code below.
using (TransactionGroup endCapsRecall = new TransactionGroup(doc))
                using (Transaction endCaps = new Transaction(doc))
                    endCaps.Start("Colocar os end caps"); // If inside transaction is sufficient/works here then place it here and not inside the if statement.
                                    //using (Transaction endCaps = new Transaction(doc)) // Transaction only needed here, but if above transaction works leave this out
                                    //    endCaps.Start("Colocar os end caps");
                                    //    endCaps.Commit();
                    endCaps.Commit();
Message 7 of 8
nelsonhp3
I don't think this is a good idea because in that case for each pipe there will be a new transaction.
Message 8 of 8
TripleM-Dev.net
That's why the Transaction is commented out in the loop, and only exits outside the loop.
