Refresh after every pickObject
nyhyuqdhyrmmivhncg
nyhyuqdhyrmmivhncg
I am trying to overwrite graphic of picked element(Room) in active view with temporary view properties ON, but it  only change after transaction end, and without temporary view property. Do you know where might be the problem ?
Transaction g = new Transaction(doc, "TST");
            g.Start();
            view.EnableTemporaryViewPropertiesMode(view.Id);
            try
                while (true)
                    Reference reference2 = uidoc.Selection.PickObject(ObjectType.Element,
                        "Select element");
                    Element o = doc.GetElement(reference2);
                    OverrideGraphicSettings ogs2 = new OverrideGraphicSettings();
                    ogs2.SetHalftone(true);
                    ogs2.SetSurfaceTransparency(100);
                    view.SetElementOverrides(o.Id, ogs2);
            catch (Autodesk.Revit.Exceptions.OperationCanceledException)
            TemporaryViewMode tvm = TemporaryViewMode.TemporaryViewProperties;
            view.DisableTemporaryViewMode(tvm);
            g.Commit();
            return Result.Succeeded;
TripleM-Dev.net
Use a TransactionGroup and put each while loop in a Transaction and commit after the pick.
If the changes should be retained, also commit the TransactionGroup at the end.
Something like this, could be the "view.EnableTemporaryViewPropertiesMode(view.Id);" also needs it's own transaction + commit.
TransactionGroup gr = new TransactionGroup(doc, "TST");
gr.Start();
	try
		while (true)
			Transaction gs = new Transaction(doc, "TSTSUB");
				gs.start
				try // don't use the try for esc pick action.
					Reference reference2 = uidoc.Selection.PickObject(ObjectType.Element, "Select element");
					// check here if it's a valid reference, if not end while.
					gs.commit
gr.Commit();
- Michel
nyhyuqdhyrmmivhncg
thanks it helped, but it's better to call Assimilate method to end transaction group.
TripleM-Dev.net
I knew i forgot something. 👍
- Michel
