I am trying to find the position of Linked Revit models in my Project. The locationPoint gives null and I couldnot
find the position.
FilteredElementCollector collector = new FilteredElementCollector(myDoc);//
collector.OfClass(typeof(Instance)).OfCategory(BuiltInCategory.OST_RvtLinks);//RevitLinkType
Select your link in RevitLookup and explore its properties.
Does it have a Location property?
If so, you can access that through the API.
I just noticed your identical question on StackOverflow and provided another answer there which may help further:
https://stackoverflow.com/questions/55556024/how-to-find-the-position-of-a-linked-revit-file
Look at The Building Coder discussion of Determining Host Document Location of a Linked Element:
`RevitLinkInstance` is derived from the `Instance` class, the base class for all instance objects. It provides the methods `GetTransform`, to retrieve the transform of the instance, and `GetTotalTransform` that includes the true north transform as well.
Cheers,
Jeremy
oops, answered the wrong thread by mistake, please ignore, cannot delete answer, just edit...
